So I've finally figured out how to capture iPlayer (Flash) streams, just in time to catch some Richard Strauss pieces I've had on my list. Also just in time to buy 8, but I think the stuff here is more or less version-independent. Wonder if somebody has other thoughts on this.
One other question: if I use these in the car there's a problem -- BBC orchestral (BBC 3) streams have about a 50 dB dynamic range in the music - appears that they don't use any compressors. So I need to compress car versions. What's the best setting for that? What might approximate, for instance, a FM station that's not going for the "loudest"
crown but still wants to be heard?
-Mike B
- The low end (very low - below 15Hz) usually seems to have a sharp uptick viewed in the Spectrum Analyzer (DC7), sometimes to high enough levels (-20 or even above) that it interferes with other processing. Requires multiple applications of a high-pass filter at 20 Hz and 24 db/octave. For music, I prefer the Butterworth characteristic. I've tried the brick-wall filter but it doesn't seem to work well at low frequencies - maybe I need to adjust something? I don't want to use something that affects content much above 20 Hz.
- BBC's stream is good up to a very sharp 15 kHz cutoff - sort of. There are a couple of little peaks above that, like a very attenuated FM stereo pilot, but usually in the 17-17.5 kHz neighborhood. They're generally below a CD's noise floor, but can get into the -75-80 range when there's major low-frequency content. Are these Flash artifacts and is it worth the effort to whack them (the notch filter helps).
- Sometimes they have a low-level but noticeable buzz. 50Hz notch didn't help much, but the Harmonic Filter for 50Hz buzz (just the basic), even harmonics, and only 20-25 dB attenuation seemed to do a good job of making it inaudible without hurting the rest of the sound much. Interesting that odd harmonics didn't seem to be present. Source fluorescent lights in the booth or ??
-Mike B
