Diamond Cut Forensics8 Audio Laboratory Introduced
This is a sticky topic.
  • Diamond Cut Forensics8 Audio Laboratory Introduced
    We have just introduced the latest Diamond Cut Forensics Laboratory, version 8. Here are the details:
    Diamond Cut Forensics8 Audio Laboratory contains a large number of new features, improvements and enhancements that will make it a "must have" tool for any forensics lab. Here are some of the highlights:
    New Auto Voice Tool - This is a Major new tool. It has two independent math processes that adapt in real time. One finds noise and the other finds human speech. These are then separated. This is a tool you should try first with any voice recording as it's so quick and easy.
    New Cell Phone Noise Filter - This new tool allows you to "teach" the program what a cell impulse looks like. It'll then search out those impulses and remove them and replace the pulse with interpolated good audio. You'll find this is useful on a wide variety of cell noises that are picked up by nearby recorders.
    Direct Spectral Editing is now available - This will allow frequency domain edits or interpolate functions. Not only can an area be attenuated right on the spectrogram display, but an area can also be augmented so as to be heard better.
    New Spectrogram Functionality - The tool has many enhancements but retains its super high resolution and fast speed. You can even scroll the spectrogram while playing audio. This is now a great tool to do authenticity studies.
    New DeClipper tool - Now includes two methods for the repair of clipped and distorted signals. One has an adjustable strength and the other uses a method of frequency domain interpolation. The result is that much more distortion is removed from a clipped signal.
    New Voice ID Function - Uses industry standard approach to allow you to see and rank the speech formants of a selected word, syllable or other speech. It also shows a frequency response plot and a Cepstrum graph. It provides the tools necessary for an expert analysis of speech characteristics.
    New Overtone And Sub-Harmonic Synthesizer - Allows the operator to add some "fidelity" into muffled or otherwise hard to understand speech.
    New support for Flac, Ogg Vorbis and Broadcast Wave audio file formats.
    Voice Garbler - This tool disguises a human voice making it unrecognizable as to person and the process used in non-reversible providing security sometimes needed in Forensics audio where a person needs to remain covert.
    Documentation - Spiral Bound, 570 Page Printed Users Guide and comprehensive Help File
    Some of the secondary features that have been added are as follows:
    Big Click Filter Added
    Big Click Checkbox added to the EZ Impulse Filter
    Direct Spectral Editing mode (DSE) added to the Spectrogram
    Manual Click replacement provided in the Spectrograph View
    Extended the length of the time interval capability of the Manual Interpolation Function
    Added a bi-modal algorithm to the Manual Interpolator which uses both time and frequency domain techniques for greater signal replacement accuracy
    Independent Hot key access to the Time Domain Only manual Interpolator
    Added a Sub-Harmonic Synthesizer Effect for recovering lost lower Octaves of the audio spectrum
    Added an Overtone Synthesizer Effect for recovering lost upper Octaves of the audio spectrum
    Provided Multifilter support to the DCTune Library
    Added Continuous Play Mode to the DC Tune Library
    CD Player Added to the DCTune Library
    Spacebar now starts and stops the play of any file in the DCTune Library
    Time Display added to the DCTune Library
    DCTune Library has an expanded list of default Genres
    .wav file header editor added
    Added a Shuffle Play Feature to the DC Tune Library
    Presets added to the Make Waves Signal Generator
    Entire Musical Scale Ranging from C0 to D9# added as Presets
    Data Disc Burning Capability for CDs, DVDs & CDR-Ws
    Disc at once mode added to the CD burner
    CD text support added to the CD burner
    Data Disc Burning Capability Added (CD & DVD)
    Hotkey access added for the Spectrogram Function
    Added 49 LP Phono Equalization Curves to the VPA
    Added numerous presets to other filters and effects
    Marker Transfer capability provided between the Source and Destination Windows
    Scrubbing Tool added to rock back and forth over a file sector
    Time Domain Tracking / Waveform Scrolling while playing is provided
    DC Playlist play bar scrolling and random access to play position provided
    User Selectable Display Themes provides choices of skins and color schemes based on personal preference
    Improved the flexibility of the Spectrogram Function
    Increased the Frequency Resolution of the Standard Spectrogram
    Added Gamma Control and Inverse Palette to Spectrogram
    Normalized Gain Scaling added to the Batch Processor
    Expanded Play List extension(s) support
    Secondary Sort Capability added to the DCTune Library
    Mouse Wheel controlled Zooming In &Zoom Out
    File Systems directories compliant with Win 7 requirements (Forensic Version Only). See the Appendix section for the location of Presets and demo
    wave files.
    Added Shortcuts on the Start Menu for all of the demo wave files.
    Upgrades from Previous Diamond Cut Forensics versions are $699.00.
    New Versions are $1,499.00
    For ordering details, go to the software section of our homepage located at:
    www.diamondcut.com
    A Free Demo Version of the Diamond Cut Forensics8 Audio Laboratory Software can be found at the very bottom of this link:
    http://www.diamondcut.com/store/inde...products_id=35
