Default Menu Missing???
  • Default Menu Missing???
    Hi Folks, recently I did a fresh install on my system with windows 7 and reloaded DC7, now my "default" selection on my filter menu's is missing, how can I fix this?
    I am not sure exactly what you mean when you say the default filter selection is missing. I am guessing that you mean the default filter presets is missing, is that correct?
    The Default preset for most filters is re-set to be the last filter settings that you used. All filters automatically save the changes when exiting.
    Rick
