Fast Track Pro
  • Fast Track Pro
    Subsequent to my previous thread on this issue, I upgraded to DC8 and conferred with Tracer. It's impossible to talk to a human being at M-audio - apparently they are trying to maintain Avid's tradition of famously indifferent customer support - so I was reduced to my own experimentation.
    To make a long story short, I purchased a Behringer card from Tracer which worked fine once I downloaded the Vista SP2 drivers online (the supplied manual and driver is for XP!). Then I went back to the Fast Track Pro and - sure enough - it does not supply a signal to your software or to Sound Recorder.
    Vista SP2 buyers, beware!
    That sounds like an unusal type of oversight. I wonder if they plan to correct it? Rhetorical question, actually.
    Thanks for the update.
      My guess is that you fix this - and a lot of other issues - by migrating to Win 7. But given how long it took M-audio to fix the TBIA issue (2 years!), there's no guarantee this driver works with the new OS either.
