HI!
1. I am by now experimenting with methods of getting rid of crackle on 78's. In the manual ity tells "narrow crackle" or "median filter". Is it possible to maybe use both to obtain a best possible effect, or should only one of them be used in a restoration process? if both may be used in a "crackle" multifilter chain, which one should be placed first AND may it then be placed after running the de-clicking process (EZ impulse, with settings 60/60/60)?
2. ALSO, when reading the manual about restoring a 78 it tells that the first process should be to filter out rumble using the high pass filter, then to do then low pass filter, since the hiss can "fool the algorithm". I have always practised to do the declicking and decrackling processes first. What is correct?
