First - thanks to Craig for his advice, and sorry about naming other names - won't happen again.
For economic reasons (can't afford to blow $couple hundred on a decent sound card right now), I have to use my motherboard audio. It's not bad (better than the cheap cards I had in past computers) - can go up to 96/24 for playing DVDs. However, 96/24 works for recording only if nothing else is running on the computer, and the file sizes are so big that I don't have enough processor and disk speed to crunch through them in a reasonable amount of time when filtering. So I've been using 48/24 with downsampling to 44/16 at the end, and it sounds pretty good to my less than Golden ears when working with 78s recorded at 45 then speed-converted in DC7 and from very used LPs. Would 96/24 be enough better that I should put up with the processing time and file size problems, given that the final product is a standard CD and that the audio is after all on the MB (and subject to its noise floor on top of the mixer currently used for its phono preamp)? If I could do 96/16, would that work better than 48/24?
Thanks.
Thanks.
