Display problem
  • Display problem
    Hi, I just started using DC7. For some reason, when I record an LP, the display shows the whole wav file compressed into the very left 1/4 inch of the display. The first time I recorded, it looked fine, but every one after that looks like this. Maybe I reset something wrong?
    Checking the manual, it says there is a "display limit" setting in the Edit/Preferences/General section of the edit menu, but I don't see that. It also seems to imply that Peak files are optional, but I don't see any setting for that. I did try the rebuild peak file function, but that didn't seem to do anything. Thanks, Eric
      Never mind. Found the peak file switch under the display Edit/Preferences/Display. I hit the zoom button, and the waveform display looks right. Note to self: Read manual first, then post to forum. Steep learning curve....
      Cheers, Eric
