DC8 has been introduced. Here is the new feature list that DC8 adds to the existing list:
• Big Click Filter Added
• Big Click Checkbox added to the EZ Impulse Filter
• Direct Spectral Editing mode (DSE) added to the Spectrogram
• Manual Click replacement provided in the Spectrograph View
• Extended the length of the time interval capability of the Manual Interpolation Function
• Added a bi-modal algorithm to the Manual Interpolator which uses both time and frequency domain techniques for greater signal replacement accuracy
• Independent Hot key access to the Time Domain Only manual Interpolator
• Added a Sub-Harmonic Synthesizer Effect for recovering lost lower Octaves of the audio spectrum
• Added an Overtone Synthesizer Effect for recovering lost upper Octaves of the audio spectrum
• Provided Multifilter support to the DC Tune Library
• Added Continuous Play Mode to the DC Tune Library
• CD Player Added to the DC Tune Library
• Spacebar now starts and stops the play of any file in the DC Tune Library
• Time Display added to the DC Tune Library
• DC Tune Library has an expanded list of default Genres
• Broadcast .wav (BWF) file support added
• .wav file header editor added
• Vorbis (Ogg Vorbis) Lossy Compression File Support added
• FLAC (.flac) Non-Lossy File Compression File Support Added
• Added a Shuffle Play Feature to the DC Tune Library
• Presets added to the Make Waves Signal Generator
• Entire Musical Scale Ranging from C0 to D9# added as Presets
• Data Disc Burning Capability for CDs, DVDs & CDR-Ws
• Disc at once mode added to the CD burner
• CD text support added to the CD burner
• Data Disc Burning Capability Added (CD & DVD)
• Hotkey access added for the Spectrogram Function
• Added 49 LP Phono Equalization Curves to the VPA
• Added numerous presets to other filters and effects
• Marker Transfer capability provided between the Source and Destination Windows
• Scrubbing Tool added to rock back and forth over a file sector
• Time Domain Tracking / Waveform Scrolling while playing is provided
• DC Playlist play bar scrolling and random access to play position provided
• User Selectable Display Themes provides choices of skins and color schemes based on personal preference
• Improved the flexibility of the Spectrogram Function
• Increased the Frequency Resolution of the Standard Spectrogram
• Added Gamma Control and Inverse Palette to Spectrogram
• Normalized Gain Scaling added to the Batch Processor
