Filter presets
  • Filter presets
    Hi - is there any way I can get back the original default filter presets after the 'autosave default preset' was checked in Preferences?
    Restoring Factory Presets
    I think just uninstailling and then re-installing the software will get you back to the factory presets.
      Then you can save them as 'original default' and click back on autosave defaults.
        I figured as much guys - I'll do just that
        Thanks for the quick response
