I need to change the sample rate of about 120 wav files from 48.0KHz to 44.1KHz. When I use the batch filter, the process works OK, but I receive an error message after each of the files has been operated upon. The message says
ERROR: Could not rename the file
C:\Users\root\Documents\DC7\dctmp26.pkf to the file
E:\Working\abc.pkf
Then I have to click on OK before the next file in the queue can be processed. It is tedious having to nurse a batch process in this way. What is my problem - is it something to do with file permissions, and how can I overcome it?
The other batch filters that I have tried do not give this error message.
I am using DC v 7.15 on Vista Home Premium 64-bit.
Thank you
Paul
E:\Working\abc.pkf
Thank you
Paul
