If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Put the system in Classic Edit mode (Uncheck Fast Edit Mode in the Edit/Preferences/General Menu).
Highlight the portion of the file of interest (in yellow). Open the File Conversion Filter. If the file is mono, set it for a mono to mono conversion. If stereo, set it for a stereo to stereo conversion.
Run the File Conversion Filter. The file in the Destination window (the one below) will be just the highlighted sector. You can use the File Menu to now name the Destination file to your choice of names.
I've always done the same as Dan, but I did not know about (or maybe I forgot about) the method Craig mentioned. It's always great to learn something new.
