If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
If you are running CE, I wonder if it has the facility to perform the ffts needed in the CNF? Anyway, there is a preference item under the general tab called something like "Use Alternate FFTs".
Try it and see if that helps.
Sorry about the shorthand. The OS is media center edition (MCE) and I have SP3. I'm going to attempt another d/l and reinstall and see if that corrects the problem. If not I'll come back to this unless someone has a better idea.
Ok, I see. I have not seen this and can not think of anything that could cause this except if the Filter toolbar is not showing at all. Look under the View menu and see if all the various toolbars are enabled.
OK...
I have d/l'ed and reinstalled DC7 and opened up a source file. All filters in the filter tool box open with a dialog box except Continuous Noise filter.
What happens when I open the CNF is that a dialog with continuous noise filter on opens in the status bar. When I right click on that dialog, a dialog comes up with add point, reset point count and delete point. Any and all ideas are welcome. Would it help to talk to tech support? (way out of warranty)
And now for the punch line...all of the filter dialogs were right at the top of the screen but the the cnf was sitting at the very bottom and looked like a minimized dialog. a click drag to the top solved the problem. I'm getting senile...
So, if I understand correctly, it seems that the cnf is now working correctly? Also, is this a problem that just showed up one day, or was it there from the beginning? Lastly, what rev are you running - - - I believe that the most current version is 7.15 (which can be downloaded from www.diamondcut.com).
ps - the warranty does not run out after a year; if the software has a bug, we try to fix it if we can trace it down, so it is always good to check the website for updates (which are free).
Yes, CNF now working. Just started doing some files after a long layoff. May be a problem self generated. I am running 7.15 and thanks for the info on warranty;.
program is very rich in features and excellent results.
