LP's copied to R to R tape
  • LP's copied to R to R tape
    Will removing original RIA from tape and re applying new RIA have any benifit?
    These tapes are from late 50's stereo 3&3/4 IPS.
    Hi Walter,
    Short answer is no. The reason is that you would be perfectly reversing an imperfect curve (that was recorded a long time ago by way of a preamp of unknown performance characteristics) and then re-creating it again perfectly which would leave you with exactly what you started out with.
    I hope that makes sense.
      LP to RtoR
      Thanks for quick reply.
        I have noticed that my old 3.75 ips Reel to Reel tapes of vinyl records sound better after giving them a treatment of the VVA (Virtual Valve Amplifier - - - usually in "sweet" mode) and a little treble boost (about 3 dB) using the VPA (Virtual Phono Preamplifier). I do this before the de-noising process which seems to produce the best overall results.
        keywords: transferring 3.75 ips r-r tapes of records, transferring 3.75 ips reel to reel tapes of records, enhancing 3.75 ips reel to reel tapes
