Group,
Question on using the Continous Filter.
I have a Continuous Noise Filter in a Multifiler. I thought that I had saved the sample of noise and the threshold settings by using the "save command in the filter window.
However, when I used the filter with another record, I did not have the same noise sample "picture" and the threshold settings didn't look the same. All other settings were the saved ones, also the other settings in my multifilters were correct.
Does the continuous noise filter need a new "sample" each time it's used ?
Regards,
Regards,
