I would like to see an option to allow crossfades across cut (CRTL X) boundaries, which would make life very easy when doing things like seamlessly shortening the gaps between performances in live recordings. Instead of a hard cut, the new option would crossfade the material before and after the cut.
The duration and shape of the crossfades would be adjustable; constant voltage and constant power are the two logical choices.
There are several ways to work out the details. I think any one of them would be satisfactory. One would be to let the borders of the cut define where the crossfades end. Another would be to let the borders define where the crossfades begin. The former would guarantee that any material inside the cut area was not heard, so I think it's probably preferable.
Another application of a soft-border cut is as an alternative to the Interpolate command, particularly when the amount of material removed is more than the Interpolate command can accommodate without audible artifacts. The soft-border crossfade would remove a little bit of the program time, but in many cases this is acceptable.
In a multitrack music production program that I use to create music (as opposed to restoration, which I do in DC7), I use crossfades all the time to create composite vocal tracks from multiple takes. In many cases, the crossfade makes the difference between a glitchy edit and one that sounds totally smooth. Indeed, the old analog tape splicing blocks allow cutting tape at a 45 degree angle for a very good reason -- it created a crossfade at the splice.
