Group,
I have a 78 RPM recording (Pistol Packing Momma) that I am restoring. The method is :
1. Play the record at 45 RPM.
2. Use a RIAA style preamp (Dynaco) to feed into the sound card.
3. Change the speed to 78 RPM with the change speed tool.
4. Apply the conversion tool for EQ. with Preamp RIAA and record 78.
Question is, Since the record was played back at a lower speed than normal, did the frequencies of the record get shifted lower and hence the RIAA in the preamp boost the "wrong frequencies"? If so, then the software didn't correct the record properly, since the software thought that the recording was played back at the correct speed and the RIAA EQ in the preamp was thought to be correct.
I know that the best way is to use a "flat" preamp, but I don't have one at this time.
