Low frequency removal
  • Low frequency removal
    I am new to this but have managed to remove Hi frequency noise from my files and keep voice's audible but I'm having on joy when it comes to Low frequency removal with out losing voice audibility on a home made film file I'm trying to restore .is there any one that can help me with this . is so please contact me.i can email a sample of the file to listen to if required, thanks Sid.
    The CNF should be able to remove low frequency noise. Two things are critical to know about it, however.
    You need to use a large fft size (16,384) to improve its effectiveness on the bottom end of the spectrum. Also, you may have to "tweek" the blue graphical inflection points (sometime called "touch points") for optimal results at the bottom end. Give that a try.
