I have been using DC6 for about a year now and I love/hate the Paragraphic EQ.
I do all my restorations using a flat preamp and I find that the preset curves for this filter work very well as a rule. HOWEVER, there are times when there is no curve present for a particular recording. One such case is when dealing with old Decca 78s which use a curve rated 250N-D. (A 250 Hz crossover, no bottom shelf and -6 dB @ 10kHz with a 3 dB/octave slope).
So: How does one make their own -6dB @ 10 kHz, 3dB/octave filter??? I can see no mathematical rhyme or reason to the placement of the data points using this filter.
It also concerns me that many of the slopes of the 78 curves appear to be around 4 dB/octave instead of 6 dB/octave as they should be. This makes me question how accurate it can be to try to adjust the data points visually using this filter.
Norm
Norm
