Diamond Cut DC7 Family of Products Ships this Week!
  • Diamond Cut DC7 Family of Products Ships this Week!
    The DC7 family are the audio restoration products to buy if you want unsurpassed audio restorations that produce dramatically reduced noise with no distortion or digital artifacting.
    New and Improved Filters:
    • Virtual Phono Preamplifier (VPA) added
    • EZ Enhancer Effect added
    • Narrow Crackle Impulse Noise Filter added
    • Narrow Crackle Control added to the EZ Impulse Filter
    • Elevated the performance of all of the Impulse Filters
    • EZ Clean Filter Performance has been enhanced
    • Greatly increased the accuracy of the Manual and Automatic click replacement algorithms providing better interpolation for application on long-lived Impulsive events.
    • Brass/Solo Discrimination Mode added to the Impulse Filters
    • Added Artifact Suppression Mode to the Continuous Noise Filter (CNF)
    • Continuous Noise Filter now supports small FFT sizes as low as 32 points.
    • Added 2 New Modes to the File Conversion Filter
    • Added a new Tube type to the VVA
    • Added a Power MOSFET (Transistor) to the VVA
    • High Noise Suppression Mode added to the VVA
    • Added a Variable Frequency Mode to Punch and Crunch Multiband Dynamics Processor
    • Added Symmetrical, third order crossovers added to the Punch and Crunch Multiband Dynamics Processor for reduced cross-talk between bands
    • Greatly improved the performance of the Stretch & Squish Time Compression algorithms
    • Pitch Changer added to the Stretch and Squish Time Compressor
    • Added a Clip LED indicator to the Dynamics Processor
    • Greatly Increased the Range of adjustability for the Dynamic Processor Attack & Release times making it more useful as a noise gate
    • Added 88.2 kHz to the Sample Rate Changer
    • Make Waves Generator Frequency Ranges extended into the Ultrasonic Range (100 kHz)
    • Full support for up to 20 Filters in the Multifilter including Comprehensive Preset saving capability added
    • Many new presets added, 1,270 Factory Presets provided for ease of setup
    • Change Speed Compensator now has direct entry of resulting time
    • Keep Residue Modes added to the Average and Median Filters
    CD Burner:
    • CD Burner Integrated into the System with Drag and Drop Capability
    • Can burn a CD from any playlist or import WLS, XML and M3U playlist formats
    CD Ripper:
    • Rip All Tracks to One File with markers added
    • Adjustable CD Rip Rate Limiter anywhere from 12 X down to 1 X
    • Extensive file naming capability added
    • Auto CDDB feature added
    • ID3V2 tags automatically added to mp3 files
    DC Tune Library:
    Added a Comprehensive File Database System called the DC Tune Library - Here are some of the DC Tune Library Specific features:
    • Automatically builds a Database from your hard drive(s)
    • Sort and Search the Database
    • Create a CD from a Playlist or selected tracks
    • Create batch file lists directly from the Playlist
    • “Previewing” of any file or playlist through any Filter without opening the file in the editor
    • Hide, Display and rearrange Tune Library columns
    • Uses mp3 and WMA tags
    • Ability to Mass-change tag information
    • Easy Creation of playlists from the database
    • Double Click to play a file
    • Open Folder that contains the tune of interest
    • Edit selected DC Tune Library track in DC7
    • Drag & Drop files from tune list into playlists
    • Drag to re-arrange files in a playlist
    File/Interface and Editing improvements:
    • Added WMA File Format Support
    • ID3V2 tags added to the mp3 files
    • Spectrogram Added to the standard Commercial (non-Forensic) version
    • “Preview From Here” feature added to the Right Mouse Button
    • Added a Shaded Time Domain Waveform View
    • Open Last File on Startup Preference added
    • New color scheme for all filters.
    • Re-arranged the Icon Tool Bars to more functionally logical groupings
    • Horizontal Scroll Bar Added to the Batch File Editor
    • Added Left and Right Channel Markers to the Time Domain Displays
    • Set Levels Button added to the Record Dialog Box to Adjust Soundcard Levels
    • Make Waves Generator includes Data Entry Format Sampling Rate
    • Toolbar Disk Icon changed from “Save” to “Save As”
    • Spectrum Analyzer Font Size controlled in the Preferences Menu
    • New keyboard shortcuts added
