Fade to Null
  • Fade to Null
    I can't figure out what setting I should use, to completely fade to silence; it seems every fade out setting I use, I get a "drop-off", because there is a small amount of signal that still remains.
    Should I extend my highlighted fade into the next track?
    Anybody have any suggestions?
    The end point for a fade out curve for 16 bit PCM audio should be set for - 100 dB on the Gain Changer. That will cause it to fade to silence. You can move the inflection points to achieve this with the range set to -100 dB.
