Stripping audio from an MPEG file
  • Stripping audio from an MPEG file
    I have an MPEG file that plays fine using Windows Media Player. I would like to convert the sound track to a WAV file and operate on it using Forensic. Is there an easy way to do this, or must I play it on another machine and feed it in analog?
    Thanks
    Yoda
    There's an 'extract audio from video' feature. Just move the pointer thing down when you open the file and there's a list of video formats - one is mpeg. Then you can extract the audio from it.
    I keep trying to get Craig to put in an 'extract video from audio' feature for DC7, but so far he hasn't committed. I would love to be able to see Edison making cylinders!
      That would be a great feature, indeed. We are working on it! Stay tuned.
        Thank you .. .thank you.. thank you....
        It worked like a charm..... longggggggggggggggggggggggg process though...
        I read War and Peace... and watched my kids grow up while waiting....
        Thanks................
        Yoda
          Where is this filter located?
          I do not see it listed in any of my menues (DC-6 Forencis)
          Video file opens but I get error and DC6 shuts down when I click on save.Do not choice fot type of video file.
            Hi Walter,
            It is found via the following path:
            File Menu \ Open Source \ Files of Type \ Video Files
              Thanks I thought it would be simple.
              I still get error and DC^ Shuts down when I try to extract and save as wave file.
                What is the file format? Is it one of the items listed such as:
                .avi
                .asf
                .mpg
                .mpeg
                  AVI
                  I was able to play video with my editor and record audio into DC6
                  and save as wave file,no errors.
                    I have had problems with certain formats of AVI files, but it's been a couple of years since I had any problems with them. It was when I had an ATI card to save material from TV shows. I used different software now, and don't have any problems. I'm guessing it would be the specific characteristics of the AVI file.
                      Thanks for info, I just needed 2.5 min of audio,copied OK!
