You can reduce tracing distortion on badly worn stereo LP's by using the channel blender with the following settings:
Set both sliders all the way down.
Check the "Blend to Mono" Checkbox.
Check the "Above" Button.
Do Not check either of the "Invert" checkboxes.
Set the "Hz" parameter somewhere between 4000 to 6000 Hz. Experiment to find the best value to reduce the distortion.
This method will trade-off some stereo seperation for reduced distortion.
Note: If you normally run this effect to reduce turntable rumble by blending to mono below a few hundred Hertz, just set up two of these in the multifilter with one set up as a rumble reducer and the other as a tracing distortion reducer.
