16 2/3 rpm: when to do NR?
  • 16 2/3 rpm: when to do NR?
    I worked on a 16 2/3 rpm LP a couple of days back (first time for me) and am battling to get rid of crackle. It doesn't seem to make any difference whether I do the NR before or after speed change (recorded at 33 1/3 rpm). Anyone care to share their workflow with 16 2/3 rpm records?
    Hi Big Al,
    As far as your crackle problem, I don't have any answer for you as I have never worked on any 16 2/3 discs. It does sound like the same problem I had a while back with some "home made" AudioDisc 78's. I do remember I had to use a lot of filters both forward and backwards and still wasn't completely happy with the results as they were so very noisy. Someone else may be of more help there.
    When I was very young, I had a neighbor that was my age. His parents had a bunch of what I thought were very different records, at least compared to what I had. They were mostly 78's and some 16 2/3 discs. From what I remember the 16 2/3 RPM records had stories on them (children's stories? don't really remember - his mother was a elementary school teacher...) One of the sets I remember his showing me I thought was kind of strange. Those 16 2/3 RPM records had 2 different tracks on each side for a total of 4 tracks per record. But what was different was the second track on each side didn't start halfway into the record. It also started at the beginning of the record side - as a second lead in groove! Since I was a kid, I have never seen another record like that (let alone seeing another 16 2/3 at all). I just thought it was interesting. What's on the 16 2/3 discs you have, if you don't mind my asking?
      There is a thread dealing with noise reduction when you also have a speed change to deal with somewhere here. I think the general consensus was that the best thing to do is to use the presets before the speed change if possible, at least for some things like the crackle/pops/clicks. In your case, it sounds like you would start with the settings for 33 1/3, since the rise and fall times, etc. associated with the noises are resulting from those speeds.
      For general noise reduction (such as CNF) I think it would be best to go with the filtering after the change of speed because you'll be able to hear it better in preview.
      That's what I recall, though. It might be best to search for that thread on here. It was a few years ago, but search for "speed change" and see what shows up.
        I have not restored any 16 2/3 RPM records, but Dans suggestion sounds correct to me. First, de-click etc at normal 33.33 speed then change the speed. Lastly, de-hiss using the CNF and apply any other filters that you deem necessary (averaging, median, EQ, etc).
          Thanks all will have another bash (and search the forum as Dan suggests).
          Originally posted by DJBohn
          Hi Big Al,
          The one I'm working on is called "The 100 minute laugh" and features a bunch of British and South African comedians as well as Art Linklinkletter and Victor Borge from the US. That's probably what makes the crackle more noticeable as there is a lot of speaking. Imagine 100 minutes on a single LP - beats CD!
          I also had a 45 rpm multi groove record when I was a kid. It was a horse racing "game" where you'd get a different result every time you started the record. I don't remember, but I seem to recall about 10 different results.
