How do you reset the default setting to the original spects? I was experimenting with the settings and lost the original settings.
Default Setting
You will need to uninstall the software and then re-install it again to regain the factory presets. If you do not want them to change in the future, goto the preferences menu under "General". There is a checkbox there labeled "Auto Save Default Filter Preset". Uncheck it and the presets will remain at the factory values after shutting down the program each time."Who put orange juice in my orange juice?" - - - William Claude Dukenfield
