Wagner is not known for brevity! I was recording an historic radio broadcast today which was 3.5 hours in length. I hit the 2GB limit around 2:06:26 at which point recording just stopped. The manual states:
"Extended Recording
Record material of any length- No 2 Gig Wave file Limit
Wave files are limited in length to 2 Gbytes. In some situations, it is desirable to record for a period of that exceeds this 2 Gbyte limit. The Extended Recording Feature accommodates this situation. It works by automatically opening a new file when a particular file approaches the 2 Gbyte limit. When you save the Extended file(s), you will see that the file(s) will be named in the following format:
xxx_part1
xxx_part2
xxx_part3
xxx_partn
Each file will have to be played or processed independently thereafter."
Does anyone else have experience using Extended Recording? Did I do something wrong?
Just for background, I was using the DC6 record function, 44.1kHz, 24-bit, and the sound card is a Creative Sound Blaster Audigy 2 ZS Platinum. Windows XP Home SP2. This is my first problem ever with DC6. A search of FAQ for "extended" yielded nothing.
- Brian.
"Extended Recording
xxx_part1
xxx_part2
xxx_part3
xxx_partn
- Brian.
