Key Board and 96/24
  • Key Board and 96/24
    Unable to stop or start from key board when recording or playing files recorded using 96/24 using forensics verison.
    I recorded a 14 minute file @ 96/24 and the resulting file was 1hr,14 minutes long and 900 plus MBs. Is this a windows thing or caused by DC6?
    Hi Walter,
    Here is a test that I ran on Live-Forensics. Maybe you can try to reproduce this test yourself and report back on the results:
    Using the "Make Waves" signal Generator I created a wavefile by using the following settings:
    Stereo
    Sine Wave
    24 Bit Resolution
    96 KHz Sampling Rate
    1000 Hz
    600 Second Length
    After clicking "OK" about 1 minute lapsed and then the file appeared in the Source display area. Using the space bar, I was able to stop and start playback.
    I did not try a longer file like your situation (600 seconds is the limit of the Make Waves Generator). But, if you could try to do what I did, that would be a good starting point to diagnose this. Please report back.
    Thanks
      Thanks for the sugestion
      The test worked fine.This seems to be a random problem since it dose not happen with every file.I get a lot of DC6 has run into a problem and must close messages during an extended session where I run several indivudal filters and donot save files after each process.I am using XP PRO,3 Gig dual processor ,1 Gig ram and 250 Gig drive.
        Since that test worked, I am wondering if your sound card may be creating corrupted 24 bit / 96 KHz wavefiles. That might explain some things, but it is just a thought - - - I really am not sure.
