CD Bug In Tunes
  • CD Bug In Tunes
    Group,
    If I hit the CD button in DC 10 the software will "see" my CD player\burner in my system. If I start DC 10 and then run the Tunes Library, the same CD button will not find my systems CD player\burner.
    Hmmmm - I am not sure if the burner is intended to be used at the same time as the DCTunes system. We will look into it and get back about it.
      Note: Just tried this again. After using the "playlist" tab to burn a CD from a playlist in DC Tunes...the software found the CD in my system.
      So...if you launch DC 10 , then tunes, then hit the CD button, the software will not find the CD drive on your system. But, if you launch the CD burner application from the playlist pull down menu, it will work.
      ​Note that DC 8.5 does not have this bug.
        I am not sure what the intended logic is there. We are looking into what it is supposed to do. Maybe we designed it so that there must be a list available for the burner? Not sure.
