Using DC6 with DC Audio Mentor
  • Using DC6 with DC Audio Mentor
    Some of you may be using both DC Audio Mentor and DC6 (or Live6 / Forensics). The simple jobs are quickly completed with DC Audio Mentor whereas the tougher ones may need some help from DC6.
    If you are using DC Audio Mentor and discover that you need a more advanced filter and you own DC6, just click on the ADV (Advanced) arrow button located in the upper left hand corner of Mentor. It will launch DC6 and the file will appear in the source display. Then, you will be able to run the comprehensive feature set associated with the DC6 program on that file.
