Font size
  • Font size
    Running Audio Mentor for the first time, it's too large for my screen; that is, the lower set of 4 buttons (the last one is "exit") are off the bottom of my screen. How can this window be resized?
    what is your screen size set to? You may want to go with a higher setting and big fonts.
    ...I meant resolution, not size.
      Sorry, but the main window cannot be resized. It should work on all screens of 1024x768 or greater. What resolution is your monitor set at?
      Rick
        Increasing screen resolution did the trick - thanks!
