title: "AN-20 Audio Restoration, Enhancement & Authentication Terminology"
description: "This document provides basic definitions of some of the terminology found in the Diamond Cut Productions family of Digital Signal Processing (DSP) software products. These terms are used in the program proper as well as in their help-files and the…"
url: "https://diamondcut.com/docs/an20-audio-restoration-terminology/"
updated: "2022-01-31"
category: Application Notes
# AN-20 Audio Restoration, Enhancement & Authentication Terminology
This document provides basic definitions of some of the terminology found in the Diamond Cut Productions family of Digital Signal Processing (DSP) software products. These terms are used in the program proper as well as in their help-files and the user’s manuals.
Here is a [link to the pdf](https://www.diamondcut.com/AppNotes/AN20-Terminology.pdf)
