Often, we receive questions regarding the performance specifications of the CTP 1000 magnetic phono preamplifier. I thought that I would publish them here for anyone interested in such a thing:
CTP 1000 - Computer Transfer Preamp
(Specifications are typical and subject to change without notice)
Frequency Response: 10 Hz to 150 KHz, +/- 1 dB @ 2 Volts Peak to Peak Output
Maximum Output Voltage Swing: 5.75 Volts Peak to Peak w/ > 8.35 VDC Power Supply
Slew Rate: 3.25 Volts / uSec
Voltage Gain: 28 dB
Channel Separation: 60 dB @ 1 KHz
Total Harmonic Distortion + Noise: < 0.008% @ 1 KHz
Signal to Noise Ratio (Referenced to 2 Vrms Output, A Weighted): 80 dB
Input Terminating Resistance: 47 KOhms
Output Impedance: 1 KOhm, Unbalanced
Power Supply Input Voltage Range: 8.35 Volts to 12 Volts DC
Power Supply Input Power Requirements: 9 Volt Battery or External 9 Volt DC Source
Power Supply Input Current: 3.5 mA @ 9 Volts DC Input, Quiescent
Power Supply Input Current Maximum: 14 mA @ 12 Volts DC
Power Supply Maximum Input Power: 170 mWatts @ 12 Volts DC
Price: $99.00 plus S&H
Note: It can be purchased at our online store located at www.diamondcut.com
keywords: CTP-1000 Specifications, CTP-1000 Specs, CTP 1000 Specifications, CTP 1000 Specs
Voltage Gain: 28 dB
